The Hyperspark should be a big step forward. Once I added the Hyperspark to my setup I was able to solve a bunch of tuning issues. I reduced fuel by 30% at freeway cruising speed and about 20% at idle. There is probably more fuel reduction to be had once I spend more time with the timing map.
