I don’t know why you wouldn’t just go out and try the stall test. It’s free, easy, only takes a few minutes, and would give you valuable info.........for having a phone conversation with a converter shop, or just for knowledge about the overall combo.
Not to mention, if the converter flashes way less than 5000, then that dyno sheet becomes even more puzzling.
Edit: I went to the TA site...... looks like their 518 converters are 10”.
I would expect a motor combo like yours to flash a tight TA 10” to around 4000-4200 doing the high gear test.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
