I thought that was the express purpose for the whiplash cam....to wake up a low compression smog motor like mine?
Yes but in a car with 4.10 gears not a 4x4. The whiplash cams are ground for low vacuum at idle and a rumpety idle for more show than go. Not usually a good choice for an efi system.
