Not sure what your car weighs? But on motor the 440 I put together would run 11.30’s on motor at a weight of 4100. With the numbers you got I am sure you will be happy. I think I used a PAC 1916 @1.885 with a titanium retainer on my build with Hughes 1.6 rockers. From 6800-7400 if I remember correct it only dropped 20 some HP. I was impressed.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
