The sheet on the exhaust says 160 seated and 380 at .620 lift. Coild bind at .775 lift. So they must be the comp springs. Not sure why they're worded differently. Seems the .025" installed height gives a decent amount more load. My curiosity is: Shouldn't the heavier intakes need a bit more than the exhaust if you wanted them different? Or is there a reason to have more spring on exhaust? You got it. I edited my last post, I don't think you saw it. Ok. Not sure if it was a typo or I don't quite get it lol. You said a race car would be 1.88-1.90 and the same for a street car. Should I make them all 1.9 or intakes 1.88 and exhaust 1.9?
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
