Rained off and on all day yesterday. Took the opportunity to help some friends - lots of attic time pulling wire.
The old dist has one pickup coil with a two pin connector that matches the zigzag connector I have been using to drag on the intake. The other pickup has a three pin connector that has two exposed pins and one covered. The old dist has no built-on vacuum advance like the one on the dist that came with the conversion kit. I hope to get the old dist put back in today - going to be cold but not suppose to be raining.
