I run a 440 source 505 , 4.25 stroke 7.1 rod . 11.0:1 . 272@050 solid flat tappet , .600 lift . In my Satellite has gone 10.53s and over 126mph best so far . So around 615 flywheel hp .But this does run a 5000 stall and 4.1 gear . This is my daily that I also bracket race . I went Dougs 2"headers - way better plug access over the 1 7/8 hookers . I have Source CNC heads by Modern . Has only been running since January but no issues other than getting the 4150 carb right . I shift at 6000 trap 66/6700 , 28"radial slick There would be more hp in a roller cam , better heads and a 4500 carb but I am happy
Tex Very impressive!
'63 Dodge 330 11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs. 10.01 @ 133mph with a 250 shot of nitrous an a splash of race gas. 1.36 60 ft. 3,700 lbs.
