My friend is running at the 4-wides this weekend. Looking at the notes for round 1 stock class eliminations...... Weather was 87deg, 50% humidity, 29.38 baro, 3250' adjusted altitude.
Car is showing 508hp on the Moroso slide rule in those conditions...... Which is more than it made for corrected hp on the engine dyno.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
