Originally Posted By csk
Originally Posted By RMCHRGR
The top of my sheet says Channel Group; Corrected Torque and power. Dos not say standard, J607 or SAE.
If I use 'standard' correction factor with my motor, it would seem to be pretty close to what I saw flash on the screen which was 521. The correction factor is .955 so 500/.955 = 523.
I'm not sure if that's how a dyno works though. Do you see the uncorrected torque/hp numbers on the screen before the printout or should you be seeing the already corrected data on the screen during the run?
That means the DA was better than the standard air, you had mine shaft air when your engine was run , so it took power away, most time it is the other way
mine shaft air would add power, not take it away. thats why cars run better at a track like Englishtown vs Denver.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
