People can go buy parts for you but are not suppose to work on the car unless they are in DW(fellow DWers are allowed).. if you break down you can have a wrecker pick you up but has to drop you off in the same place
Be careful about this advice, I don't think you are allowed to have a wrecker pick you up and drop you off for repair, even in the same spot.
From the rules:
"•All vehicles must be driven under their own power during the entire Drag Week competition and may not be towed, trailered, pushed, or hauled at any time. The exception is in the event of an emergency in which a vehicle needs to be removed from the roadway or other dangerous situation, in which case assistance may be used to move the car a short distance to a safe area, for example, to the next highway exit."
Pretty sure if they catch you on a tow or haul (other than the noted exception) you are out!
I seen it in person a few times.. they picked up the car and they dropped it off in the same place.. hot rod didnt have a issue
