Re: converter selection, need some pointers
[Re: gregsdart]
#2219291
12/22/16 10:46 PM
12/22/16 10:46 PM
Posts: 13,247 Mt. Vernon, Ohio
dartman366
Mt. Vernon, Ohio
Just a guess on what will please you for driveability; it sounds like a stock configuration 10 3/4 Mopar converter, set up to act just like a factory original yet be built for the abuse a 540 can deliver is what will work well for you. I used exactly that converter behind a 535 cube wedge with a 590 cam in it, and it stalled plenty high yet was tight enough to not flash a lot higher at a light throttle application. If you take the K factor into consideration, it will give you an idea of what it will do in the car. Those converters were used behind 340s ,383s, and street hemis I believe. The stall behind a street hemi was about 2800 from what I have read, and 2400 behind a 340. That same converter stalled quite a bit higher behind my 535, like mid 3,000 or more. A couple of things make me think this might be the right path for you. You want street drivability over ultimate performance for one. The other is street traction. A motor like that ought to be able to fry the tires at low speeds anyway, so a high stall loose converter just isn't needed much there. GregI hope you are not inplying that this car is street driven as it hasn't seen the highway or city street in over 20 years, it is a dedicated bracket car, altho I would just love to take a blast thru the neighborhood just once and pizz off the neighbor's down the street. ![drive drive](/ubbthreads/images/graemlins/custom/drive.gif)
Light travels faster than the speed of sound,,,this is why some people seem bright untill you hear them speak.
Entire Thread
dartman366
12/19/16 01:58 AM
12/19/16 02:34 AM
Sport440
12/19/16 02:45 AM
Monte_Smith
12/19/16 05:42 AM
12/19/16 02:36 AM
J_BODY
12/19/16 02:44 AM
wyoming
12/19/16 02:53 AM
MR_P_BODY
12/19/16 03:18 AM
ProSport
12/19/16 05:15 AM
MR_P_BODY
12/19/16 05:19 AM
ProSport
12/20/16 01:41 AM
12/19/16 02:40 PM
earthmover
12/19/16 03:10 PM
MR_P_BODY
12/19/16 04:23 PM
67mprfan
12/20/16 03:34 AM
mopar dave
12/19/16 05:05 PM
sr4440
12/19/16 05:30 PM
12/19/16 05:34 PM
MR_P_BODY
12/19/16 05:58 PM
dartman366
12/20/16 03:56 AM
polyspheric
12/19/16 05:46 PM
fast68plymouth
12/19/16 06:01 PM
sr4440
12/19/16 09:02 PM
sixpackgut
12/20/16 03:17 AM
69dart
12/19/16 09:22 PM
Monte_Smith
12/19/16 09:24 PM
383man
12/22/16 08:12 AM
fast68plymouth
12/19/16 10:21 PM
MR_P_BODY
12/19/16 10:39 PM
12/19/16 11:45 PM
Cab_Burge
12/20/16 12:13 AM
J_BODY
12/20/16 03:28 AM
J_BODY
12/20/16 04:01 AM
theraif
12/20/16 05:14 AM
Whompin_Wedge
12/21/16 11:46 PM
dartman366
12/22/16 02:36 AM
ProSport
12/22/16 03:50 AM
Chassisman
12/22/16 04:04 AM
gregsdart
12/22/16 10:36 PM
dartman366
12/23/16 02:46 AM
Sport440
12/23/16 03:19 AM
gregsdart
12/24/16 02:53 AM
dvw
12/22/16 11:18 PM
Thumperdart
12/22/16 11:51 PM
Chassisman
12/22/16 11:58 PM
Thumperdart
12/23/16 12:00 AM
493_DART
12/23/16 01:07 AM
fast68plymouth
12/23/16 06:01 PM
fast68plymouth
12/23/16 06:09 PM
dartman366
12/23/16 07:51 PM
eds dart
12/23/16 11:55 PM
VernMotor
12/24/16 02:03 AM
A39Coronet
12/24/16 02:13 AM
savoy64
12/24/16 02:24 AM
A39Coronet
12/24/16 02:51 AM
Eric
01/05/17 05:40 PM
dartman366
01/06/17 03:12 AM
dartman366
01/08/17 10:50 PM
67mprfan
01/09/17 02:50 AM
justinp61
01/09/17 04:29 AM
Eric
01/09/17 04:04 PM
Al_Alguire
01/09/17 10:57 PM
dartman366
01/26/17 02:15 AM
fast68plymouth
01/26/17 05:17 AM
KOS
01/27/17 12:53 AM
Thumperdart
01/27/17 02:20 AM
dartman366
01/27/17 03:02 AM
dartman366
01/27/17 02:52 AM
fast68plymouth
01/27/17 03:02 AM
dartman366
01/27/17 03:04 AM
