Re: converter selection, need some pointers
[Re: dartman366]
#2219175
12/22/16 06:36 PM
12/22/16 06:36 PM
Posts: 10,020 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Just a guess on what will please you for driveability; it sounds like a stock configuration 10 3/4 Mopar converter, set up to act just like a factory original yet be built for the abuse a 540 can deliver is what will work well for you. I used exactly that converter behind a 535 cube wedge with a 590 cam in it, and it stalled plenty high yet was tight enough to not flash a lot higher at a light throttle application. If you take the K factor into consideration, it will give you an idea of what it will do in the car. Those converters were used behind 340s ,383s, and street hemis I believe. The stall behind a street hemi was about 2800 from what I have read, and 2400 behind a 340. That same converter stalled quite a bit higher behind my 535, like mid 3,000 or more. A couple of things make me think this might be the right path for you. You want street drivability over ultimate performance for one. The other is street traction. A motor like that ought to be able to fry the tires at low speeds anyway, so a high stall loose converter just isn't needed much there.
Entire Thread
dartman366
12/19/16 01:58 AM
12/19/16 02:34 AM
Sport440
12/19/16 02:45 AM
Monte_Smith
12/19/16 05:42 AM
12/19/16 02:36 AM
J_BODY
12/19/16 02:44 AM
wyoming
12/19/16 02:53 AM
MR_P_BODY
12/19/16 03:18 AM
ProSport
12/19/16 05:15 AM
MR_P_BODY
12/19/16 05:19 AM
ProSport
12/20/16 01:41 AM
12/19/16 02:40 PM
earthmover
12/19/16 03:10 PM
MR_P_BODY
12/19/16 04:23 PM
67mprfan
12/20/16 03:34 AM
mopar dave
12/19/16 05:05 PM
sr4440
12/19/16 05:30 PM
12/19/16 05:34 PM
MR_P_BODY
12/19/16 05:58 PM
dartman366
12/20/16 03:56 AM
polyspheric
12/19/16 05:46 PM
fast68plymouth
12/19/16 06:01 PM
sr4440
12/19/16 09:02 PM
sixpackgut
12/20/16 03:17 AM
69dart
12/19/16 09:22 PM
Monte_Smith
12/19/16 09:24 PM
383man
12/22/16 08:12 AM
fast68plymouth
12/19/16 10:21 PM
MR_P_BODY
12/19/16 10:39 PM
12/19/16 11:45 PM
Cab_Burge
12/20/16 12:13 AM
J_BODY
12/20/16 03:28 AM
J_BODY
12/20/16 04:01 AM
theraif
12/20/16 05:14 AM
Whompin_Wedge
12/21/16 11:46 PM
dartman366
12/22/16 02:36 AM
ProSport
12/22/16 03:50 AM
Chassisman
12/22/16 04:04 AM
gregsdart
12/22/16 10:36 PM
dartman366
12/23/16 02:46 AM
Sport440
12/23/16 03:19 AM
gregsdart
12/24/16 02:53 AM
dvw
12/22/16 11:18 PM
Thumperdart
12/22/16 11:51 PM
Chassisman
12/22/16 11:58 PM
Thumperdart
12/23/16 12:00 AM
493_DART
12/23/16 01:07 AM
fast68plymouth
12/23/16 06:01 PM
fast68plymouth
12/23/16 06:09 PM
dartman366
12/23/16 07:51 PM
eds dart
12/23/16 11:55 PM
VernMotor
12/24/16 02:03 AM
A39Coronet
12/24/16 02:13 AM
savoy64
12/24/16 02:24 AM
A39Coronet
12/24/16 02:51 AM
Eric
01/05/17 05:40 PM
dartman366
01/06/17 03:12 AM
dartman366
01/08/17 10:50 PM
67mprfan
01/09/17 02:50 AM
justinp61
01/09/17 04:29 AM
Eric
01/09/17 04:04 PM
Al_Alguire
01/09/17 10:57 PM
dartman366
01/26/17 02:15 AM
fast68plymouth
01/26/17 05:17 AM
KOS
01/27/17 12:53 AM
Thumperdart
01/27/17 02:20 AM
dartman366
01/27/17 03:02 AM
dartman366
01/27/17 02:52 AM
fast68plymouth
01/27/17 03:02 AM
dartman366
01/27/17 03:04 AM
