On those headers I built I had to bevel the surface of flange to clear the plug socket.. but that is with 3/8" flanges... with the LA gasket did you end up with the hole that are close to the port.. I always use the holes that are out farther so port work doesnt get into the holes that I mount with.. I am just into the close holes with porting
