The plate in the VB blocks off the hole for the center bottom bolt. I thought about drilling it but decided against it and just left the bolt out
Once the governor is removed, there isn't a need for a perfect seal back there so a missing bolt doesn't matter. The 904 and 727 have different hole locations at that point, thus the elongated hole.
