Thread 2 3/8 bell housing bolts in the holes on the pump and use a small crow bar to bump the pump out. if it is a 69 it should already have the good non controlled load servo on the kickdown band. I would eliminate the cushion spring on the rear servo. They make a spacer but you can stack some washers to do the same thing.
How thick is that spacer?
1/4 inch I do believe. There is an ad in the classifieds on here for a nice billet servo that does the same thing as well as an accumulator with a built in blocker rod that's a nice piece as well.
