Originally Posted By DaveRS23
Drop the valve body and tap the pump housing off from the inside out. I use a long 1/2" extension.
I always use A&A's bearing that replaces the thrust washer between the input and output shafts. I have beat that thrust bushing out on a couple of trannies. You loose 3rd gear just all of a sudden and it requires a near total tear down to replace.
Whats that bearing called?
