Thats a really good idea Andy, do you sell those adapter brackets?
@Barracuda7199, I cannot find a number on my kickdown lever, is it really tiny?
What you have pictured is the throttle pressure lever and since you are going to a RMVB you will not be using it when you put the transmission back in. The kickdown lever is the one that pushes on the strut that closes the 2nd gear band and they are numbered.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
