Any air bubbles in the radiator when running? how old is the water pump? any wetness at the seep hole.
Water pump is two years old. If I run with cap off, I may get a single air bubble every now and then. No leaks anywhere that I can see. I've spent time under truck with strong light while running and while pressure testing. Saw no leak.
