Doesn't the 6 pack setup ultimately flow around 1350cfm? hard to imagine the carbs being the limiting factor on horsepower, especially when you consider how fast people are going on a single dominator.
Tunnel ram intake with removable top and and a 6 bbl adapter would be neat. anyone ever done anything like that?
No it really only flows about 950cfm
I will not dispute you, however I have seen the 1350 figure from multiple sources, including Hot Rod
http://www.hotrod.com/how-to/engine/mopp-0801-mopar-six-pack-tuning/
Where did you find 950?
Now I see 1030? the outboards are considered a 500 cfm carbs but they're really not.
https://board.moparts.org/ubbthreads/showflat.php?Number=7515387
John just wishes he had one..
I did at one point , my first 69 RR had a 440-6pk ...
