Cool...How much power will that block safely handle? How many cubes can you get out of one? Are you running a stock oil pan? Can you buy headers and mounts that fit your car? 727 with adapter??
Hey Wayne, I made my headers and oil pan as I love making stuff, but like Gut mentioned, there's plenty of stuff available to put one in darn near anything. As for max cubes, I know a few companies make a 4.25 stroke crank and the largest bore in a stock block is in a 6.4 block...4.095. Mines at 4.100. I think the MP 6.1 Aluminum Block can go to 4.188 bore. A 727 or 904 Small BLock trans bolts right up. I'm using a Turbo 400 with a JW Ultrabell.
