Re: Need a Pro Street Wiring Harness for a Cuda....
[Re: Dragula]
#1664890
09/04/14 03:19 AM
09/04/14 03:19 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
I like the central relay's, keeps it simple in my mind and away from water and heat sources. My fuel pump one is probably the closest and only relay not under the dash.
So some good idea's. I haven't pulled the trigger on anyhting, but want to just re-wire the whole car. Anyone have a diagram they used they can post?
Take some time, sit down and make your OWN diagram. Its your car, you alone know what circuits you need..........so draw it out and start stringing wire. You can speed the process a little by retaining the factory head and tail section wiring. I mean lights are lights, if they are working, leave them alone. I usually install a terminal strip under the dash on the drivers side and run the factory head and tail harnesses to that. Clean, color coded and easy to tie into with new switches. The under dash and under hood wiring on older cars is usually where the issues are, not in the lighting
Monte
