Next, I removed the axles, backing plates and lines. I bolted on some wood pieces to the ends of the housing to seal it up and had the entire thing sand blasted.
I darkened the center section to get rid of the blasted look. I traced the white stencil from the side of the original center section onto a piece of transparent paper. Then I used some transfer paper and copied it to the other center section. I should have had a stencil made so it would look better but it is what it is. I also put back the two yellow marks on the bottom and the orange mark on the top.
After RPMing the center section and installing a new seal and metal dust cover, I think the center turned out pretty good.
