Quote: What wideband set up did you go with? For carb tuning I always liked the lm1 with rpm converter, and added a narrowband sensor/ map sensor in the aux inputs. This gives you load, rpm, actual a/f ratio, and happiness a/f ratio. Very usefull info...
Went with the LC-2 "DB" kit ( Summit pt # SUM-G2995 ). Basic kit, so I don't have all the other available plug-ins at this time.
