Re: My 1970 Dart TKO-600 install
[Re: MadMatt]
#1611650
04/28/14 02:12 PM
04/28/14 02:12 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
Nice Wor.
Passon's transmission is geared toward the mopar owner that refuses to do any modification to install any non factory. If you aren't afraid of a then there is no reason not to do what you did, you have a transmission with aftermarket support that is eaier to get parts for and rebuild yourself ... not a knock against Passon's transmission , it is what it is .
I agree. Passon's transmission looks like a terrific bit of engineering and I certainly considered it. But the combination of cost and other factors pushed me the way I went. And even with Passon's trans I would have had to weld in a new floor hump and z-bar supports if I went with a mechanical linkage. So, overall, the amount of fab work involved wasn't much more. Maybe just a bit more thinking, measuring, and planning.
Plus, going this way, I had local support from Modern Driveline and a ton of aftermarket solutions to choose from for any problems.
Conversion to the stock mopar setup, linkage and all supports, is a piece of cake compared to what you did, I did it in my backyard when I was 17.
