The reason I ask, is you have two independant systems on here with no common area... One side could have 5 psi and the other could be at 15. at surge areas you will have two high powered 4 cylinder engines fighting with eachother. Without a common area tuning will be an absolute nightmare. At the least you should combine the turbo outlet tubing at some point. I'm not trying to be a critic, just food for thought. I go along with the common theme in this thread and say I love it!
The intakes have a balance tube and the cold side plumbing will be balanced as well
