Ok, well I just degreed it and it came in at 107.I can move it in 4 degree increments if i want.this is a stock engine keep in mind in a street only car. The comp lifters are kinda strange,the pushrod cup sits down farther in the lifter and is loose,you can rattle it.the pushrod cup sits .087 lower down than the cup in the lifters im replacing so that is going to affect my pushrod length again..............
