Quote: The engine leak tested perfect(under 15%) and compression is 140psi across the board.
Neither of those #s look good to me. IMO, a good leak test for a reasonbly fresh engine would have been 5%, and unless you've got some mongo-huge cam in their killing all the cranking pressure, 140 psi is what I'd expect out of a stock 383.
