I called Inline tube,,they wont take the lines back,,said it's their policy
If you want to make use of the lines you're stuck with, just remove the plug from the prop valve and remove the spring and valve; reinstall the plug and the prop valve becomes a distribution block.
I wouldn't consider putting a prop valve in a 4-wheel disc system until some road testing was done.
The INTERNET, the MISinformation superhighway
