Thanks Lefty! Appreciate it! I have a complete set of new lines,,got em a few days ago from inline tube. How do I use these lines that go to some sort of Prop. valve/distribution block. Do I just get a set of "adaptors or joints" to extend the lines to each wheel? Thanks for the input! BTW,, I called Inline tube,,they wont take the lines back,,said it's their policy,,therefore the question. Also last but not least,,can you or anyone suggest a stainless steel brake line flaring tool? The Napa tool is just not rigid enough, and most I seen on Amazon or other brake tool suppliers are the same flimsy tool and is not for stainless. I don't mind spending good money for proper high quality tooling.
