I noticed a wideLSA cam likes lots of compression, convertor, and RPM, and real good heads. All things a typical 59 degree Mopar small block doesn't need or have N/A.
That said, shift recovery seems improved over a narrower cam.can't see any Benefit to a 112-114 stick with Indy, W5, W2, Eddie, ect stroker builds Pro stock.... Sure
I have the Indy 360-2 heads,10.9 comp. 255/266@ .050,5500 PTC convertor and shift at 6800. It made peak hp at 7300 on the dyno. I am thinking about spraying 100/125 shot of NOS.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
