Isolate the fuel lines as much as possible from engine heat and insulate where you can't. Isolate the carb with a spacer and shield. After that , you have to look at what you are running. Pump gas is really bad these days......I think we are getting the EPA / cost cutting measures combo platter from the pump these days. Maybe a system with a return ?
