I think the problems are with newer units, not olders
you are in a better position than most people here to answer that since you tried rebuilding them! did you see any difference?
need to find good quality transistors... the ones I found are chinesse junk, and only worked to discard where it weas the fail, what it prooved the fail was there.
Actually after get the Rev-N-Nator, left on a side the testing of more transistors, but will try to work on that again
With a Charger born in Chrysler assembly plant in Valencia, Venezuela
