Quote: Ok so for an update, i stripped the entire motor down and noticed that there was a chunk taken out of one of the cam lobes.
I had a 360 stroker that had same bearing issues due to 3 worn-out camlobes had sent the trash through the mains, chewed them up badly first. Rodbearings looked better.
Had to regrind the crank etc. after a full tear down. Same has happened with other engines that ruined camlobes. Just to let you know. Hope it works out for you!
So you think i'll be alright with just turning the crank down and installing new bearings? (i'm also gonna hone, and put new rings in)
And what did you do to fix this, just install a higher quality cam? Mine looks like the original.
