bores look good, but no crosshatching. If those bearings are dated 99 then that probably lines with his story. If i got the crank straigtened away, and put new main and rod bearings it. Shouldn't it be good to go?
My only fear is that maybee it got some shoddy workmanship. Either that or i destroyed the bearings some how.
