Seriously look at the 200...
http://www.bigblockdart.com/forum/showthread.php?21132-Going-with-200R4-transmission-in-my-Dart
I have a 4L60E in my '95 GMC 1/2 ton. It is fine, but 1st to 2nd is just a large drop in RPM. If the torque is there to power through it, might not matter much. If I remember correctly the 60 is just an updated 700 (that might be oversimplifying a bit). They can be built too, but consider an 4L80 while you are at it if you are going down the 60 route.
4L80 is a HUGE tranny compared to the 60 and would require tbar/floor mods....if you're doing that, I'd go with a 518/46RH
yes, correct. All depends on what this is going into.
383, Hemi 4-Speed, AlterKtion, D60
