Quote: Mark, Great picture! What kind of times were you running? Also, what power windows setup did you go with? Arno
Arno, The power window kit was from It's a Snap! 866-462-7628 I notice there is a plastic sleeve I need to install on the cable feed for the regulator. That cable rubbing the inside of the door may be why it sounds bad. I hope/think it may quiet things down some when I install that sleeve. Also, my doors are fiberglass and seem to resonate the sounds. Mark
Update: I installed the sleeve and the regulator isn't too bad considering there is no door panel on it presently.
Cool, Thanks Mark. I am getting close to where I will need to decide on one setup or another. Any preferences out there? Arno
