I hope that's not Donalds car, but it looks alot like it. I have seen it many times. You are most likely going to have to fend for yourself if your car is on fire and I never see any fire fighting equipment at the finish line at any event short of national events.
I just added an onboard fire system for this reason. I will be adding a seperate system later that will have the nozzles under hood only.
