I had the same oversize nose cone problem with a starter I bought off ebay. The guy said he sold many of those starters with no problems. When I measured the end it was larger then the original. He took it back and I ended up buying a rebuilt starter from autozone. It fit perfect. I wish I would have read your post earlier I may have saved you a lot of trouble. Mike
