You use the little plastic jar with it, and pull a vacuum through it, and it sucks the air/brake fluid through the lines/caliper and fills the jar. Just empty it out before it gets to the top and gets sucked into the vac of course
Oh, and I used my mityvac to reverse bleed my clutch system, worked perfect for it as well!
