Re: torque per cube?
[Re: gregsdart]
#578469
01/12/10 11:46 PM
01/12/10 11:46 PM
Posts: 2,966 Wendy, I'm home.
dstryr
Wendy, I'm home.
I am curious what some of the best packages produce for torque per cube. I and I think a lot of other guys would like to see how the various heads work, and what is possible. Non mopar combos wellcome for comparison. Please give head type, induction, cam type (specs also), usage. Thanks, Greg
Greg,
This is my 505" street car engine that was finished up in November:
Here are the basics:
1966 440 block +.030"
440 Source 512" kit
440 Source heads, valve job, back-cut valves Porting: 254cfm initial, 283 after porting on the intake side
.044" ROL head gasket
Squared and decked, pistons -.004"
10.2:1 compr. approx.
Comp Cams XS290S Comp Cams EDM lifters
Smith Bros Pushrods
Harland Sharp 1.5 roller rockers S70015K '69 6 bbl induction system with Promax outboard metering plates, center metering block, and rear adj. base
Stock dist. with Pertronix Ignitor conversion and Flamethrower coil
Doug's D452 2" headers
598hp, 651 lbs/ft torque on 91 octane pump gas.
1.29 lbs/ft tq/cubic inch
dstryr, since 1986.
