Re: torque per cube?
[Re: MuscleMike]
#578448
01/11/10 11:57 PM
01/11/10 11:57 PM
Posts: 2,840 Flint, Michigan
B1Fish540
Flint, Michigan
622", 11.3:1, solid roller, 150psi cranking, 92 speedway premium, 1.4 per cid.
B1 heads are odd because they don't flow enough air relative to the port size (or CSA: cross section area) on a big inch combo the port is big enough to support the cid but the flow isn't there to support RPM so the engines tend to nose over early.
Mike @MM
Thats because they are a wedge and have limited valve size, right? Does the TS also lack flow for big inch motors?
