Do you know what a separator bottle is... 2 tubes going into a bottle(just through the top) hook your PCV hose(from the carb) to one side of the bottle then hook the other to the PCV hose, that will put the bottle in line as a collector.... you might need to do the same on the breathers(larger hose will slow the volicity).... thats about all I can suggest untill you find the cause
