Now do the same thing with the breathers open/working,
also what gauge are you using.... is it like 1 - 5 psi,
being really low you should use a inches of water...
but dont worry
ok, will try that. i'm using a vacuum/fuel pressure gauge. testing it out, 1-2 lbs of pressure isn't that much, so i'm sure it is good enough for this.
