I had the same problem with my Cuda when I first got it fired up. No smoke whatsoever but ate 6 quarts of oil after about 500 miles.
It was sucking the oil into the intake ports from under the intake due to poor alignment and not enough sealant. I think it only had the valley pan initially and I ended up having to add the thin gaskets as well with that special gasket sealant.
