Good point about the bushing! This is VERY important if using the poly bushing vs the stock press in bushing. I've seen some guys weld and extension onto the pivot shaft, then weld a large washer on the end of it around the circular base in the control arm. While this does work, I would Tig this area, due to the possible stress incurred.
