Yeah, pull the rotor off and turn it upside down. Next to each screw hole you'll see either a small male square, or a small male circle. You'll see the circle and square holes near the weights on the dizzy. Make sure they're indexed correctly on the dizzy. It's likely not the problem, but it's good to make sure it's on correctly.
And you're jumping the neg. side of the coil to ground, and the black meter wire to ground?
Yep, it should be a half hour job.
I'll check back later, I've got errands to run. Maybe check the PN on the module against Pertronix's list.
