It almost looks like an inverted/deformed rosette…is the other one the same? You’ve owned since ‘70 so no messing there…I almost doubt they’d stop the line because of bad rivet(s)…while the worker would have to grab a set of correct ones? Just my thought…J code so I see your concern too…
