Quote: By all means, feel free to fix it! By the way....how many times in your "artistic" life do you think you have written your name (twice) the exact same way?
Actually, I could.
If your arguement is that Carter could have had more than one vendor for their labels... Then yes, you'd be correct.
If they had only one vendor, and the printer used the same printing plates every time they printed the label (as is common practice)... Then the label should be the same every time. Well, there could be slight color variations due to ink and pressure variables. But the Trademark and registration symbols shouldn't change like these appear to. And their seems to be a very, very slight font issue and maybe a slight issue with the little car logo... But it is hard to tell in the pic.
Over all, it is a VERY nice reproduction with nice art work. The minor variations that I see certainly wouldn't be noticed while stuck on a carb on an engine in a car. However, I'd be sweetin' it out if I was using it as documentation to get in and out of a country.
