Quote: One of your goals on your latest projects is to have the fewest repro parts possible, so which do you choose, the original which in the best case will still be yellowed somewhat, or the repro for the same look as when new?
I am using the original bottle. I spent HOURS using every method I could to remove/eliminate any exterior staining that might have existed. Since it is a chemical composite breakdown within the plastic, it was impossible to get a cleaner looking finish. The plastic oxidized (yellowed) beneath the top surface! The washer bottle on my A Body is VERY nice but has some signs of discoloring. At least it has done so consistently and not in a splotchy fashion!
