Line pressure in Reverse increases by a factor of about three so the increased pressure helps weak parts that would fail at the lower pressure in forward gears.
If by "wimpy lever" you mean a low ratio like 2.9, setting it at 1.75 turns out is a bad idea...the lower the ratio the more turns out. For that lever go at least 2 turns or 2.25.
